Using parameters with Jira Cloud for Sheets
Fabio.Cabral
December 17, 2024
Hello!
I'm using the "Jira Cloud for Sheets" extension and running a macro that calls the "JIRA" function from a cell. The function looks like this:
'=JIRA("(project = FP AND issuetype in (Story, Task, Bug) AND resolutiondate >= 2024-10-28)", "key,summary,issue type,status,Created,resolutiondate")
My question is: how can I provide the resolutiondate as a parameter instead of hard-coded?
Lucas Modzelewski _Lumo_
Did you try experimenting with sheets today function?
https://support.google.com/docs/answer/3092984?sjid=9854440490088339623-EU
Somehow I was thinking that you want to pass date from sheets ;)
for JQL function check: https://support.atlassian.com/jira-software-cloud/docs/jql-functions/#startOfDay--
Fabio.Cabral
December 17, 2024
I was looking for something like this:
  • Cell B1: the JIRA function with a reference to cell B2 (resolutiondate >= B2)
  • Cell B2: the resolution date
But I don't know how to do this :'(
can be done, but not directly, you need to change your parametr to text before you send it to Jira (and make sure it matches Jira date format)
here is some basic example with formulas used:
Like Fabio.Cabral likes this
Fabio.Cabral
December 18, 2024
