Hi friends.
How can I use perforce server in MyGroovy add-ons of Jira? In Scriptruner add-on I used
lib com.perforce.p4java.* classes, but can't use it in MyGroovy addon. Is there a solution that I use perforce in MyGroovy add-on?
Mamikon
You should make the Perforce library JAR available on the classpath, so that MyGroovy can import and use the classes in that.
Thank you Aron. I already have p4java.jar file. So where can I import it, that MyGroovy will be able to recognize p4java?
I understood you :). But I must say that MyGroovy plugin not at all my :). I found it from marketplace and using the MyGroovy Listener
MyGroovy is a paid app, am I wrong? If so, ask their support!
