is it possible to use rank in 2 different boards in the same project where the rank of both projects is not depending from each other?
Hello @Cathy Savinsky
Rank is a global value for an issue. If you have three issues in a project ranked as
Issue 1
Issue 2
Issue 3
...then in any board where any combination of those issues appear their rank in that board will be the same. You cannot have them ranked as above in one board and then, for example ranked as follows in another board:
Issue 3
Issue 2
Issue 1
Help us plant more trees
