Using request type name in atomation rules
Alexey Paveliev
January 7, 2025
Hello community,
I add a static text prefix to summary by using Edit issue action with the value:
  • whatever text I add  {{issue.summary}}
Has anyone figured if the name of the request type can also be used as a value?
So if user create a ticket of type "Create new user" with a random summary, the rule would add "Create new user" to that summary
Lucas Knorr
January 7, 2025
@Alexey Paveliev I want to mention another way of approaching your requirement.
Are you already aware that you can provide default values in a request type? SCR-20250107-tkci-2.png
If you want to stick to your current way. You can use this smart value
{{issue.Request Type.requestType.name}}
to receive the request type name.
Alexey Paveliev
January 9, 2025
@Lucas Knorr thanks a ton.
The smart value you provided worked. That's what I was looking for!
I knew about the hidden values and we use them a lot, but it would not work for the case at hand
Jakub Cieslak January 7, 2025
Hi, I am not sure if I got it right, but if you are looking for a smart value that will print the name of the Issue Type, you can use this one:
{{issue.issueType.name}}
Alexey Paveliev
January 9, 2025
nope. Request type is not the same as Issue type.
If I use what you provided I get "Task" not the "User Access" or whatever a type service management is configured to have
