Using selected fields only in JIRA API ?
Mansi_Gusain February 10, 2025
Hey, I want to access a few relevant fields only, from the following API-
https://<domain-name>/rest/api/3/issue/OS-663
when I hit it in postman, I am getting all the fields, just need the important and relevant data only from the api.
I tried getting the author id and comments only, no success please help if this can be done.
Vishal Biyani
February 10, 2025
@Mansi_Gusain
In Query Params, add a variable
fields and value as the relevant field that you need e.g. summary, priority etc
Mansi_Gusain February 11, 2025
https://<domain-name>/rest/api/3/issue/OS-663?summary like this?
Vishal Biyani
February 11, 2025
like this
https://<domain-name>/rest/api/3/issue/OS-663?fields=summary
Like Dirk Ronsmans likes this
Thankyou so much!!
Vishal Biyani
February 11, 2025
Great. If this works for you, please accept the answer
Brother one more help . How can I get the space id and parent id ?
I want to create a confluence page from postman how can i do that?
The api i am using is- https://<domain>/wiki/api/v2/pages and the body -
  "spaceId": "<string>",
  "status": "<string>",
  "title": "POSTMAN",
  "parentId": "<string>",
  "body": {
    "representation": "storage",
    "value": "hi"
Vishal Biyani
February 11, 2025
The response is a json object. You will need to parse it. This is enclosed inside results list
are there some permission required to get the spaces?
Like from the space end?
Okay............... but where can i find the space id and parent id? from
Vishal Biyani
February 11, 2025
I don't have much experience using confluence APIs and Postman. Better to post the question tagging confluence, so that folks who are experienced in Confluence APIs can respond.
In terms of permissions, given that confluence space has permissions, so you would need to have permissions to query the space.
Okay thanks for your help.
Mansi Gusain
hey for this api- https://domain.atlassian.net/wiki/api/v2/spaces?fields=name
all fields are coming is there a way to just get name and id?
Vishal Biyani
February 19, 2025
as per the documentation, there is no query parameter to restrict number of fields.
This API is returning the json object. So, looks like you will need to parse for name from the results body.
Mansi Gusain
 okay thanks for the response
FREE
