×I am trying to create a Jira issue when the submit button is clicked on the form. How can I add a macro to the button to create the Jira story automatically from the ConfiForms field definition values?
Thank you Alex, your response is quite helpful response. However, now I am getting this error:
com.atlassian.sal.api.net.ResponseException: Error communicating with Jira, {"errorMessages":[],"errors":{"summary":"You must specify a summary of the issue."}}
Here's my noformat content:
"fields": {
"project":
"key": "MAFS"
"summary": "[entry.summary.escapeJSON]",
"description": "[entry.description.escapeJSON]",
"issuetype": {
"name": "Story"
My issue is now fixe. The error above got cleared when I used the fieldname correctly with the proper case.
Thank you Alex.!!!!!
Hi
Yes, everything in ConfiForms is case-sensitive - you need to follow the letters case everywhere.
In field names, in function names, in field object properties (for rich objects, such as Page/User, for example)
Alex
