Sign up Log in
V.Urgent Jira is not working
Sisir Kumar Senapati June 28, 2018
JIra is not working in our instance please check ASAP
https://processmap.atlassian.net
Andy Heinzer
June 28, 2018
Sorry to hear about this problem.  However I believe this was in regards to an incident that happened today that affected some Jira Cloud sites.  I see that you created a support request for this problem as well.  We documented this problem in https://status.atlassian.com/incidents/9t2gkjp7l29m
This issue appears to have been resolved at this time.
While we are happy to try to help with these kinds of problems here in Community, in the future should you find your Atlassian Cloud site is not functioning correctly, it might be a better route to reach out directly on https://support.atlassian.com/contact and then select Technical problem, your product, in this case Cloud, and enter your URL.  This ensures that your report is handled directly by our Cloud support team.
