VS Code plugin Start work screen has no repository
Will Wong
February 15, 2022
When using the JIRA plugin on VS Code and navigating to the Start Work screen the repository dropdown is blank.
This was working fine a few months ago, is there something that needs to be configured/reconfigured after a recent update?
Will
Jesper Bundgaard
February 23, 2022
Hi Will,
I have tried a lot of different things regarding this issue for the last couple of hours, and it is working now. I am not sure that's the only reason, but it seems that it solved the problem when I installed  the "github.vscode-pull-request-github" extension in VSCode!?
Jesper
Mikael Dam
April 1, 2022
Same issue. The above, did not fix the issue.
Jesper Bundgaard
February 23, 2022
I have exactly the same issue, and have also tried to change different settings, but without luck. It is still working fine on an older installation on my other laptop.
Any suggestions?
Jesper
Marco Guinter Alberton
