Validate some fields before create a task or subtask
Matteo March 21, 2024
I need to validate some custom fields, for example that the value on custom filed is not greater than a certain number and so on, before creating a task, otherwise a warning or message appears, how can I do that?
Nic Brough -Adaptavist-
March 21, 2024
You can use validators to do this, but you will need to find an app that provides a validator for "number is larger/smaller than", the built-in ones do not have that
Matt Parks
March 21, 2024
I know that Jira Script Utilities (JSU) is an example that does have this type of field validator. I would imagine the Jira Miscellaneous Workflow Extensions also has this ability, although I've used that plugin much less.
Matteo March 22, 2024
Tank you, i'll try with the JMWE.
John Funk
Hi Matteo - Welcome to the Atlassian Community!
Unfortunately, this is not available. You might be able to use the ScriptRunner Behaviours add-on app, but I think it is very limited as to custom fields.
Help us plant more trees
