Validate work log event if no work description is provided
Sadeesh Narendran
June 19, 2021
Hi All,
I want user not to succeed creating a worklog if no Work log description is provided. I want to prompt user "Please add Work Log Description when he tries same.
I have Jira automation enabled, I am able to check trigger when work log event is created, compare if worklog.comment is empty or not, if empty I don't see any option for prompt or stop the event or prompt user to enter description.
Is there a way to validate this? I am stuck here.
Note: This has nothing to do with validators in Workflow transition
Sadeesh N
Alexander Eck [Tempo]
June 21, 2021
Hi @Sadeesh Narendran
you actually can´t stop the creation of the worklog.
What you can do is to delete the worklog (when the description is empty) and send a message to the user who has entered the worklog.
In case you have Tempo Timesheets installed you can configure the worklog description to be mandatory which will enable the worklog validation checker.
BR
Sadeesh Narendran
June 21, 2021
Arsheen Banu Syed August 24, 2021 edited
How to delete the worklog?
Niteshkumar Shah February 16, 2023
Tempo does actually have the option to make Description mandatory.
Administrator -> Manage Apps -> Tempo -> Global Configuration
