Validator on Assignee's group
Gaetano Turturro
September 23, 2025
Hi there,
with a ScriptRunner validator on the issue creation workflow transition, I’m trying to verify that the assignee belongs to a specific group (not to a role).
I had no problems when testing it by assigning a task to myself (as administrator).
However, when I made this validator operational, an error came up because the property of belonging (or not belonging) to the group is not visible.
Any ideas on how to resolve this?
Using a project role is an option, but I would prefer to use groups.
Gaetano
3 votes
Maciej Dudziak _Forgappify_
September 23, 2025
Hi @Gaetano Turturro
The thing is, when you try to read user project roles or groups in a Jira expression, you need Project Administrator or Global Administrator permissions, respectively. Since the validator runs as the current user during a transition, and that user might not have those permissions, it won’t work in that case.
Cheers
Gaetano Turturro
September 23, 2025
"Broswe Groups and Users" global permission could be enough?
September 23, 2025
This is what official docs says:
  •  groups: The list of names for all the groups the user belongs to. Note that, while you can access your groups, you need Administer Jira global permission to see groups other users belong to (List<String>).
  • N groupIds: The list of IDs of all the groups the user belongs to. Note that, while you can access your groups, you need Administer Jira global permission to see groups other users belong to (List<String>).
  • N getProjectRoles(project): Returns a list of project roles the user belongs to for a Project. Note that, while you can see the roles you belong to, you need Administer Projects project permission for the project or Administer Jira global permission to see roles of other users (List<ProjectRole>).
Gaetano Turturro
September 23, 2025
Screenshot 2025-09-23 130245.pngSo, a new question:
If I fire a post function that checks whether the assignee belongs to a group before the issue is created, can I stop the transition (and therefore the creation of the issue), or would I have to delete it afterwards?
September 23, 2025
No, only validators can prevent the transition. I don't think thats possible using Assignee field. You can on the other hand create custom User Picker and in configuration filter the selection to a group.
Like Gaetano Turturro likes this
Gaetano Turturro
September 23, 2025
The solution I’ll use is a required custom User Picker field (restricted to the target group) named “Confirm Assignee”, plus a validator that ensures Assignee = Confirm Assignee. Thank you very much for the help
@Maciej Dudziak _Forgappify_
@Kristian Walker _Adaptavist_
Like # people like this
Hi Gaetona,
Validators inside of ScriptRunner for Jira expression framework.
It sounds as if the group is not correctly configured for users, which is causing the validator to fail.
I would advise you to raise this as a support request here, so that the ScriptRunner support team can help debug the validator and identify the potential issue with the group.
I hope this helps.
Kristian
