Validators Checkboxes JMWE
Tyas Iglecias February 2, 2020
I want create validation  with condition :
Custom field - Checkboxes : Deployment
Options :
- DR
- DC
- None
the question is how to make pop up error if user choose DR&None / DC&None/ DR&DC&None
I try used
(issue.customfield_12308.some (it => it.value == "None"))
Its work  in Test Jira Expression, but its not work after publish the workflow
Hi David,
what I want is pop up error if user choose
DR&None
DC&None
DR&DC&None
Empty
and the status can be contiune if user choice
DR
DC
DC&DR
None
What the meaning "!!" / "!" ?
!issue.customfield_12308.some(it => it.value == "None"
!!issue.customfield_12308
David Fischer
! means "not", and thus "!!" means "not not" which really means "is true". "!!" is needed to transform any "truthy" value into a real "true" value (because Jira expressions support "truthy" and "falsy" values during the evaluation of the expression, but Conditions and Validators only support "true" or "false" as the returned value)
If you need to enforce selecting at least one value, then try this:
!!issue.customfield_12308 && issue.customfield_12308.length > 0 &&
(!issue.customfield_12308.some(it => it.value == "None") || issue.customfield_12308.length == 1)
Like • Tyas Iglecias likes this
Tyas Iglecias February 3, 2020
Its Work thanks David :D
Darryl Lee July 1, 2020
Glad I finally found this answer. It would be great if this was in the KB for JMWE Cloud.
Also, do you know why the include function doesn't work like I would expect it to? The syntax of the some function always confuses me.
Radhika Vijji _Innovalog_
July 1, 2020
Hi Darry,
Because it is Jira expressions (used in Conditions and Validators of Cloud) and not Nunjucks (used in post-functions). See here for information on Jira expressions.
Radhika
Darryl Lee July 2, 2020
Weird, because that link says:
List literals
Lists can not only be obtained from context objects but also created manually. For example, to check if the issue type is either a Bug or Task, create a list with these two types and use the includes() method to test if the actual value is one of the two listed:
['Bug', 'Task'].includes(issue.issueType.name)
And on another page:
  • some(Any => Boolean): Checks if the list contains at least one element that satisfies the given predicate (Boolean).
  • includes(Any): Checks if the given argument is stored in the list (Boolean).
I think maybe I'm not understanding what the argument for includes() should look like. From the first example, I guess something like this might work?
['None'].includes(issue.customfield_12308.value)
Guess I'll play around with it tomorrow.
July 2, 2020
Hi Darry,
My bad. My statement was incorrect. As mentioned in the document, using include you could check if the actual value is one of the values listed. Whereas some is a closure that checks if the list contains at least one element that satisfies the given predicate. So in the above example, in which you want to check that "None" option is selected, some should be used to check for the value of the option, which you cannot do using include
Radhika
Darryl Lee - CCC
I guess I still don't understand the difference between includes and some.
It seems like includes should work the same way some is currently working. As the documentation says:
I tried the different syntax ['None'].includes(issue.customfield_12308.value), but didn't have any success.
David Fischer
What is the custom field type of customfield_12308? Is it a single-select field or a multi-valued field (e.g. Checkboxes)?
Also, is "None" (in your case) an actual "Option" of the custom field, or do you mean it as "no value selected"?
Darryl Lee - CCC
Hi David - it's a multi-valued Checkbox field. "None" is an actual option.
David Fischer
Then issue.customfield_12308.value is invalid, since issue.customfield_12308 returns a List of values, as shown on the Issue Fields help tab below the editor. Please use that help tab to insert the correct Jira expression for your custom field.
Darryl Lee - CCC
If I wanted to use includes, what would the correct syntax be?
I think I tried this, initially:
issue.customfield_12308.includes('None')
And it worked for the positive case (when None was checked), but I was trying to find the dispositive (?) (None not checked) and was having problems with I think this:
!issue.customfield_12308.includes('None')
David Fischer
You cannot use include with multi-valued fields. The correct syntax to check multi-valued fields such as Checkboxes is shown on the Issue Fields help tab:
In your case, you'd want:
!!issue.customfield_12308 && issue.customfield_12308.some(it => it.value == "None")
And the opposite test would be:
!issue.customfield_12308 || !issue.customfield_12308.some(it => it.value == "None")
Darryl Lee - CCC
Sorry, I'm being dense, but I think I'm getting it (slowly).
So just for clarification, is the reason includes won't work because multi-value fields are not actually List literals (arrays), but rather something like a Dict (key-value pairs), hence the requirement to do the iterations with some?
David Fischer
Not exactly. It's because multi-valued fields (multi-select and checkboxes, version pickers, user pickers, etc.) return a List of objects, not string literals. For example, checkboxes return a List of "Option" objects (in the form of a JavaScript hash, or JSON object, however you want to look at it) that contain 3 properties: id, value and "self" (a URL):
    "self": "https://jmwe-dev-local.atlassian.net/rest/api/2/customFieldOption/10100",
    "value": "Radio1",
    "id": "10100"
    "self": "https://jmwe-dev-local.atlassian.net/rest/api/2/customFieldOption/10101",
    "value": "Radio2",
    "id": "10101"
 See https://developer.atlassian.com/cloud/jira/platform/jira-expressions-type-reference/#issue for details (under "custom fields")
Like • Darryl Lee - CCC likes this
Darryl Lee - CCC
Thanks, this is really helpful! Heh, the documentation, not so much:
In addition to these, all custom fields are available and can be referenced by one of the following:
  • ID: issue.customfield_10010
  • key: issue['com.my.app.field-key']
Custom fields are returned as JSON values, using exactly the same format as in the issue REST API.
I mean I guess if I was intimately familiar with the REST API I would know they were returned as objects.
Anyways, I really do appreciate your taking the time to explain!
Ernesto Donate November 18, 2020 edited
Hello @David Fischer @Radhika Vijji _Innovalog_
Wondering if  you can please help me?
I'm trying to build a validation that will block a transition for a specific Issue type when it meets certain conditions.
IF
  • Issue Type Name = "New Award"
  • Sponsor Code(single text field) has one of the following values (5101,5105,5106, etc...)
Then
Block Transition when
  • Multi Valued Check Box field "Check all that apply" does not have the value "X" checked. In other words, the person needs to at least select the value "X", otherwise, the transition is blocked.
What I've done so far is tried to use the Field Required Validator with the following condition:
(issue.issueType.name=="New Award"
&& (!issue.customfield_10117 || !issue.customfield_10117.some(it => it.value == "X"))
&& (issue.customfield_10075 == "5101"
||issue.customfield_10075=="5105"
||issue.customfield_10075=="5106"
||issue.customfield_10075=="5107"
||issue.customfield_10075=="5109"
||issue.customfield_10075=="5112"
||issue.customfield_10075=="5118"
||issue.customfield_10075=="5124"
||issue.customfield_10075=="5128"
||issue.customfield_10075=="5130"
||issue.customfield_10075=="5132"
||issue.customfield_10075=="5133"
||issue.customfield_10075=="5136"))
But, this has not worked. Any Help would be much appreciated.
Thank You!
Ernesto
David Fischer
Hi @Ernesto Donate ,
the logic in your script is slightly incorrect. You want the script to return true when the transition should be allowed, so the first test should be to return true if the issue type is not New Award.
Try this instead:
issue.issueType.name != "New Award" || !["5101","5105","5106","5107","5109","5112","5118","5124","5128","5130","5132","5133","5136"].includes(issue.customfield_10075) || !!issue.customfield_10117 && issue.customfield_10117.some(it => it.value == "X")
This means that the validation will pass if:
  • issue type is not New Award
  • or if it is, then if customfield_10075 is not in the list of values
  • or if it is, if X is selected
Ernesto Donate November 20, 2020
Hello @David Fischer ,
This is been very helpful! I have a few related questions
  • If I want to include more than one Award Type would it be correct to use something like: !["New Award","IssueNameX","IssueNameY"].includes(issue.issueType.name)
  • In general for validators that involve multiple conditions it is correct to use the "build-your-own" option instead of the "Field required Validator" with a condition?
Thanks again!
Ernesto
David Fischer
  1. Correct
  2. It really depends. If you're really trying to make a single field mandatory, but only under certain circumstances, it's usually easier to use the Field required (JMWE app) Validator. But in your case, that's not what you're doing, since you want to test the value of customfield_10117, not just whether it is empty or not. In that case, you have no choice but to use a Build-your-own validator.
David Fischer
I assume you want validation to succeed if the user selects only "None", and fail if he doesn't select anything?
Then try this:
!!issue.customfield_12308 && (issue.customfield_12308.some(it => it.value == "None") && issue.customfield_12308.length == 1 || !issue.customfield_12308.some(it => it.value == "None"))
Which means:
  • customfield_12308 must not be empty, AND:
    • customfield_12308 contains None and no other value, OR
    • customfield_12308 does not contain None
Register now
