Version and component sync for jira
sai kaushik giddalur June 12, 2019 edited
Hi
I used the plug-in Version and component sync for Jira, configured as recommended in the documentation, but i have problem syncing versions of 1st project with the 2nd project, when i try to do so i found the releases in the target projects gets erased and replaced by the master project versions. Can anyone help me with this.
SAI
CollabSoft June 13, 2019 edited
Hi Kaushik,
This is expected behaviour using "Full Synchronisation" as your synchronisation type. When using "Full Synchronisation" Version & Component Sync will remove all versions/components in 'Linked Projects' that are not present in the 'Master' project. If you would like to be able to keep manually created versions in the "Linked Project" please use "Specific Changes" as your synchronisation type and uncheck 'Delete' in the 'Specific Changes' panel.
Please don't hesitate to contact me if you have any additional questions concerning Version & Component Sync. You can do so by opening a support ticket via our customer portal or by sending an email to jonas@collabsoft.net
Jonas Hallensleben
