View Transition screen data in activity of of issue detail view
NehaNagori June 12, 2017
I have a workflow, where each transition is associated with the sprint. I want to view each transition screen detail.
Currently, in History tab I am able to view everything. But I wanted to view these details in the seprate tab. Where it will show only transition screen data.
Nic Brough -Adaptavist-
June 12, 2017
You'll need some code to pull that out and display it separately.
If you install the Jira Suite Utilities add-on, you'll find that does a transition display tab.
This add-on is already installed in my JIRA. It is showing the transitions but not screen data.
June 12, 2017
Ok, you'll need to find or write something that displays whatever you mean by "screen data"
NehaNagori June 20, 2017
Is there any documentation for this scripting or coding?
June 20, 2017
The easiest way to get something displayed is with a scripted field - see https://scriptrunner.adaptavist.com/4.3.1/jira/recipes/scriptfields.html
But you might want to do it as a web panel, that's covered near there in the docs too.
