Sign up Log in
WARN: Establishing SSL connection without server's identity verification is not recommended
Антон_Воробьв
February 22, 2019
In the default instalation jira-core I see in log catalina.out next:
WARN: Establishing SSL connection without server's identity verification is not recommended. According to MySQL 5.5.45+, 5.6.26+ and 5.7.6+ requirements SSL connection must be established by default if explicit option isn't set. For compliance with existing applications not using SSL the verifyServerCertificate property is set to 'false'. You need either to explicitly disable SSL by setting useSSL=false, or set useSSL=true and provide truststore for server certificate verification.
In which configuration file to register the option "useSSL= alse"?
kevin June 15, 2023
These answers are all about how to modify dbconfig.xml
But my question was thrown when I initialized the page.
At this time, the dbconfig.xml file has not been generated.
I tried to create the dbconfig.xml file manually.
Still can't pass the verification of initialization page.
王林林
September 13, 2022
After adding useSSL, it does not take effect. Is there an updated processing method
Michael Aglas
except that warning is there any degredation of the tool? a functionality not working or so?
Richard Cross
If you get that warning during the setup phase, it won't proceed to configure the database, which is a pretty severe degradation of functionality.   ;-)
Like # people like this
Антон_Воробьв
February 22, 2019
edit config - /var/atlassian/application-data/jira/dbconfig.xml
in line
<url>jdbc:mysql://localhost:3306/jiradb?useUnicode=true&amp;useSSL=false&amp;characterEncoding=UTF8&amp;sessionVariables=default_storage_engine=InnoDB</url>
add useSSL=false&amp;
Nirmani K August 21, 2019
Omar Malavé
November 2, 2019
Hi @Nirmani K add it at the end of the url
warm qing February 11, 2020
<url> jdbc:mysql:// address =(protocol = tcp)(host = 127.0.0.1)(port = 3306)/ jira?sessionVariables = default_storage_engine = InnoDB useSSL = false&amp </ url>
Is it here ?
Richard Cross
But what if you're getting this error while attempting to set up Jira and connect it to a database for the first time?
Benmway July 3, 2020
@Richard Cross I have the same issue when starting jira 8.10 with mysql 5.7. Where you able to fix this?
Richard Cross
Only by ditching MySQL 5.7 and using PostgreSQL instead.  :-)
Varma Gadiraju October 30, 2020
You need to add "useSSL=false&amp;" this parameters in the dbconfig file.
Example: <url>jdbc:mysql://localhost:3003/jiradatabase?useUnicode=true&amp;"---ADD HERE---"characterEncoding=UTF8&amp;sessionVariables=default_storage_engine=InnoDB</url>
Like Parvaneh Zand likes this
Derek Mart
MySQL - 5.7.31 / mysql-connector-java-5.1.48
Added (useSSL=false) in the connector url:
<url>jdbc:mysql://address=(useSSL=false)(protocol=tcp)...
Like Jürgen Backhaus likes this
