Hi there,
I am really stuck in completing so I hope I can get help here.
My case should be simple :
To achieve this, I have tried, adding custom field condition validator. But, didn't work
What is the best way to make this comparison?
Hi @Selvakumar
One note - I don't see where this ever ends - it looks like it keeps looping forever.
Regardless, you should use Conditions not Validator. So let's take it one step at a time where you are having the problem. What is the first step that is not working for you?
And what are you trying to do?
And what custom field are you using?
And what are the values of the custom field?
From MEC CTO I have to close, unfortunately I do not have showed here
And what are you trying to do? Approval from X & Y status and them move to Z
And what custom field are you using? : Report Status (as custom field)
And what are the values of the custom field? : Approved Or Rejected
As you suggested, I need to use this custom field as condition.
So put a Condition on the transition from X to Z (For QUA Approval). Use the Value Field condition and set the Report Status field = Approved
Also, add a Condition to the transition from X to Y (PTE Rejected). Same process Report Status field = Rejected
You should be able to follow this same process for all of your transitions.
Hi, managed to complete the workflow with conditions and validators.
Using a custom field (condition & validator) done with my flow.
Register today
