Wallboard errror: "No project or filter specified."
AyJay February 26, 2015
I have this dashboard with three gadgets.
One of the gadgets is a pie chart, which displays fine as long as I am on Dashboard mode.
When I try to view it as a  Wallboard, I get the error message:
There are problems with the current configuration for this gadget. The errors below may have been caused by the deletion of entities required by the gadget or by changes to your permissions.
  • No project or filter specified.
It seems strange, considering it works fine as the normal gadget on the dashboard. And the other two gadgets use the exact same filter, and they show up on the wallboard.
What gives?
SMS
February 27, 2015
Hello AyJay,
I have responded to your ticket with us, but this does appear to be a known bug:
https://jira.atlassian.com/browse/JRA-40935
Any users that are effected by this issue should vote to help show how many clients are affected by the problem.
Thank you for your help,
Shannon
