Want my Kanban Board Issues sorted by due date per Column
Rich Winterstetter March 22, 2018
Hi all,
I have a small problem and don't want to annoy support as I feel it is probably a lack of understanding on my part, so maybe you guys can help me out.
I want to display my tasks in the Kanban Board ranked by due date (meaning, the one with the most recent due date is on top etc.) for every column.
I already tried a quick filter "ORDER BY duedate ASC" which does precisely nothing and a separate Swimlane "ORDER BY duedate ASC" which also does not rearrange the tasks.
However the quick filter "type = "all" ORDER BY duedate ASC" ranks the tasks in the desired order, but only shows tasks of a certain task-type while leaving out all other task types.
We're running a Jira Cloud version if that is important for you guys.
Anyone who can help me? I'd appreciate it a lot! Thanks in Advance
5 votes
Andy Heinzer
March 27, 2018
Jira Software boards are governed by the board filter.  This determines what issues appear and in what order.
By default Jira Software will try to always use the Rank field as a means to order these.  At the moment you can't technically rank issues by another field other than a rank type field.
BUT, you can order the issues on the board to be displayed by another field.  To do this, you would need to either edit the existing board's filter, or it might be easier to first create a new filter (such as just "Order by due date asc", then save this filter), and then create a new board based on that saved jql filter.
The major thing to note about doing this:
You won't be able to order the issues by their Rank, nor can you change the rank of issues just by dragging/dropping them on the backlog or active view.   And you won't be able to change the Due Date just by dragging and dropping the issues.
But you can still execute transitions by dragging/dropping the issues into other columns, just as you would on a board using the rank field to order the issues.
This might not be the functionality you are looking for.  If you were wanting to be able to change the Due date value just by dragging and dropping, like you would with rank on a rank ordered board, I don't think this is going to work.   With a field type like date, there are many possible values and you probably want it to be an explicit date.  Whereas the Rank field has a value, but the end user almost never needs to know what that actual value is.  Since ranking in Jira can change that value during a rebalance, it's value is really only important in relation to other issues rank values.
Is this helpful? not helpful?   Tell us more about your use case.  Maybe we can find an alternative solution here.
Rich Winterstetter March 27, 2018
Thanks, that helps me out a lot.
Andy Heinzer
March 28, 2018
Cool, glad to hear that helps.  Let me know if you have any follow up concerns.  If this answer solved your issue, please click the checkmark to the left of my answer to accept this answer.
Rhian Parker-Wicks
May 24, 2019
Hi @Andy Heinzer , I was wondering if you would be able to confirm the JQL code for this due date filter of epics, stories and sub tasks please? Many Thanks, Rhi
Andy Heinzer
May 29, 2019
@Rhian Parker-Wicks I am not sure I fully understand your request here. But based on what you have provided I think it would look something like this
Project=ABC AND type in (epic, story, Sub-task) order by "Due Date" ASC
Not sure if you want to limit this to a single project or not here.  In this case, your epics would need to be in the same project, which isn't always the case.
Like Rhian Parker-Wicks likes this
Rhian Parker-Wicks
June 3, 2019
@Andy Heinzer thank you for your response, apologises if I didn't articulate myself very well I'm very much a beginner so getting use to all of the terminology.
To answer your question I have one Jira project with a basic Kanban view of Blocked, In Progress and Done. I've started to use the due date feature and wondered if there was a filter I could use to sort issues/tasks by due date. I've just tried adding the code you suggested but it's come back with 'Not able to sort using field 'Due Date'. Any suggestions? I hope i've provided a bit more context?
Many Thanks,
Rhian
Andy Heinzer
June 3, 2019
Ah, my apologies, I'm afraid I got the field name incorrect.  Which is why you likely see that error.  It should not be 'Due date', but rather just 'duedate'  For fields that do not contain spaces like this you do not need to use quotes.  Instead try this filter for the board:
Project=ABC AND type in (epic, story, Sub-task) order by duedate ASC
Andy
Tijs Tijert
I just tried to change my kanban board filter to be:
project = SALES AND status = Done ORDER BY "Due Date" DESC
But I get the error message: Not able to sort using field 'Due Date'.
I don't know how to get it to work.
Any ideas?
Andy Heinzer
October 9, 2019
Hi @Tijs Tijert,
Try using the JQL search of
project = SALES AND status = Done ORDER BY DueDate DESC
instead.  I think this is the same issue Rhian was having just above.  While the field name is listed as "Due Date" in the field configuration scheme, it seems that you can sort by this field if you simply remove the space to use 'duedate' instead in the JQL filter.
I'm not sure why this is just yet, but it seems to work.
Andy
Tijs Tijert
That did the trick!!! Thank you Andy!
Beakon Support June 4, 2020
I have tried the same JQL search as I also want a quick filter to sort my KANBAN by due date.  I keep getting the following message.   I clear all filters, no luck
Andy Heinzer
June 5, 2020
@Beakon Support This won't work as a quick filter.  Instead the suggestion so far has been to create a new saved filter that orders by Due Date, and then create a new board and use that filter.  This will let those issues be sorted by the Due Date instead of the default Rank.  The thing to note about this is that you cannot reorder the issues on the board by drag and drop though like you can on a board where the filter is sorted by rank.
Steve Smith
I don't think this is "nonsense" either. I need this for the same reasons as stated by others.  Backlog by priority, completed by date.  What JIRA needs is Kanban templates instead of having to write complex queries.  Data goes into the table, first it is sorted by column, then objects in each column are sorted by the user selected field.  This is how it should work, and how most other software works when tables are created.  Just because it wasn't built this way doesn't make the request stupid, it's means the software wasn't design to meet these user needs that's all.  By the way, please address this, it's the natural way of working for teams.
Tijs Tijert
Why nonsense?
I am giving my team tasks. The tasks have a duedate and a priority.
When the tasks are "In Progress" or "Not started yet" I want them to be ordered based on priority in my kanban board. But when the task is "Done" and subsequently moves to the last column in my Kanban board I want them there to be sorted based on Date of completion.
That way mt team will likely start higher priorit tasks first and I can check completed tasks based on the order in the last column.
Not possible?
Nic Brough -Adaptavist-
October 31, 2019
Why nonsense?  Because it does not make any sense in the real world.  Again, could you show me a list of the first five numbers from 0 that is in both alphabetic and numeric order?  Please tell me how to do that and make sense?
If you want to look at a list in two different orders, that's not a problem, but you will need two separate views - the same question, but with two different "order by" rules in the two saved searches.
A board works off one single search (it's supposed to be consistent), so you will need two boards to support the different views you want.
Markus_COGNITIFF
This issue has existed for years. Take a look this plugin - I think it should do what you need - https://marketplace.atlassian.com/1221621
Full disclaimer, I represent the company behind the plugin.
Andy Heinzer
January 13, 2020
Hi @Markus_COGNITIFF
Thanks for your answer here.
However please review our Community guidelines for Marketplace vendors. While all the points of that guide are important to follow, your previous answer here specifically does not identify yourself as having a relationship with the vendor of the plugin you are recommending here.  We request that you identify yourself as a partner, particularly when you are recommending your own product as a potential solution.
Andy
Connor Gamble October 25, 2019
Hi @Andy Heinzer
I've changed my board to be ordered by due date as per the above, how do I then go about changing the filter to have the columns sorted by priority as a secondary step?
At the moment they're ordered like this:
  1. Due Date: 25th October, Priority: Medium
  2. Due Date: 25th October, Priority: Low
  3. Due Date: 25th October, Priority: High
I would like them like this:
  1. Due Date: 25th October, Priority: High
  2. Due Date: 25th October, Priority: Medium
  3. Due Date: 25th October, Priority: Low
Connor
Andy Heinzer
October 28, 2019
Hi Connor,
I think I understand what you are looking for here.  In the previous examples the JQL filter is setup to use something like this:
project = XYZ AND status = Done ORDER BY DueDate DESC
But in your case, I believe that you would need to add an additional order by element, like this:
project = XYZ AND status = Done ORDER BY DueDate DESC, priority ASC
This should first sort the issues by duedate first, and then by priority in the manner you have described here.
I hope this helps.
Andy
Like Connor Gamble likes this
Connor Gamble October 28, 2019
Hi Andy,
That's exactly what I was looking for, thank you!
Connor
Tijs Tijert
Ok... we're slowly getting to some nifty sorting schemes. Now I would like to know if it is also possible to sort two status columns in different ways. So... status column done to be sorted based on date of completion but the column status = In Progress based on Priority. Can I do this in one filter or would I need to write a new filter for every status?
October 29, 2019
No, you can't do that, columns follow the sort order of the board.
Like Andy Heinzer likes this
Tijs Tijert
Ok, so how do I write two sort orderings into one filter?
October 30, 2019
You can't, because it's nonsense.  For example, can you show me a list of the first 5 numbers from 0 ordered by their value and their name at the same time?
Kim Letkeman November 12, 2019
It's actually not nonsense ... the question makes sense if filters could be written like this, but I'm betting that they cannot:
project = XYZ AND ((status = Done ORDERBY CompletionDate) OR (status != Done ORDERBY DueDate))
Does this work?
Update: Nope ... order by cannot be used as part of the query parameters ... bummer
Like Tijs Tijert likes this
November 13, 2019
They can't be written like this because you are not telling Jira what to order by.  Imagine you have 12 issues, six Done and six in other status.  You've told Jira to order half of them one way and half another, but you have not defined an order for the list itself.
A list can only have one sort order.
There is actually a way to get close to that query though, if you have one of the automation or scripting apps.  You make the order by done on a single thing.  A derived/calculated/scripted field could easily be made to be a copy of the relevant field ("if status is done, copy completion date, else copy due-date").  Then your query can be done - project = xyz order by calculated-date
