×I have over 20 tickets under an Epic and when I went to print out this Epic it did not show any of the Issues in this Epic - why?
@Elaine Gamble, where are you viewing the Epic?
For example: you should be able to print the list via the search for issues view:
We were on the actual Epic ticket - there is an Export - printable option - so this was where we were trying to pull all of the tickets under that Epic. So - I a, not sure why it is not showing any of the tickets under this Epic. What am I doing wrong?
thanks so much!
Elaine
if you are viewing the Epic issue alone then printing will not print issue contained w/in the epic. Did you attempt per my instructions above?
I did do what you suggested and it only pulled the Epic in the search are - so I went to view and I saw was printable option not "print list"
Learn more
