Sign up Log in
Want to create custom fields in release .
Ashutosh kumar December 9, 2019
I have crated one project in jira software , and in release tab can we create custom field.
Or for this any plugin require.
Alex Laycy
December 9, 2019
Hi Ashutosh,
There's a pretty good tutorial on creating custom fields in JIRA here.
Hope this helps!
- Alex
Hi Alex,
Thank you ! I have tried this.I am asking that - can it is possible to create custom fields in "releases" tag, (Jira software).For example : The "version" field.
Thank you
Ashutosh kumar
Alex Laycy
December 9, 2019
Hi Ahsutosh,
Do you mean have a custom field appear within the releases tab interface in your project?
If that's the case, i don't believe so unfortunately - if you create a custom field though you could have it appear in filters, any backlogs (added via board settings) and in any screens.
- Alex
There is status field at the release screen. After the status field, i want to add one more field.
Alex Laycy
December 9, 2019
Hi Ashutosh,
This isn't currently possible unfortunately, there is a feature suggestion though which you can vote on and watch for updates (for the server version).
As a partial workaround, you could on the top-right of the list, click on "View in Issue Navigator". Viewing tickets within the "List View" allows you to add custom columns.
Be aware though that column settings are user based.
- Alex
ramon_vandeven
January 2, 2024
How can this be "Accepted", if it's not solved? It's just still pending as the feature is not available.
Josh Muir December 14, 2022
@Ashutosh kumar Unfortunately, there is no way to do this as of now. The closest thing would be to create the notes in Confluence, which will automatically create a macro of your release notes, and then you can edit the fields displayed in the table.
If you want to create the macro yourself, here is the JQL query to insert into the standard Jira marco:
fixVersion = #
Replace # with the fix version number in the URL.
There is an issue gathering interest that you can vote for: https://jira.atlassian.com/browse/JRACLOUD-41489
Register Now
Upcoming Jira Events
