Want to fetch issue id based on label
akshay_solanki
April 20, 2022
Hey Team
we have multiple issues. in all the issue have different kind of label
like stage-FE, stage-BE, prod-FE, prod-BE and all labels are associate in single board and in single project
so i am looking for rest api from where i can get all issue id which have specific labels
earlier response is very helpfull
Oliver Siebenmarck _Polymetis Apps_
Hi @akshay_solanki ,
Welcome to the community!
So, if I get this right, you want a list of issue keys (DEV-1 etc.) of all the issues that have a specific label. I'm gonna recommend using Jira Expressions to get there.
The way to do this is to send a request to the expressions endpoint that includes a JQL query to select the issues you want. This could look like this:
labels in (stage-FE, stage-BE, prod-FE, prod-BE)
As you only want the issue keys, you also add a simple Jira Expression like this:
issues.map(i => i.key)
And that's it. The endpoint should return a list like this:
"DEV-200",
"PRJ-560",
"MAU-559"
If you only need to do this every now and then or want to play around with Expressions a bit more, I can also recommend our free Expression Tester app, which lets you run any expression quickly from your browser.
Hope that helps,
 Oliver
