Want to make custom field required based on another field value
jaya chandra reddy nellore May 9, 2022
Hi Folks,
I have Custom field Source ID(Text field) values contains like KB-*,IN-*,TE-*..etc, Now i have to create behavior script If Source ID values starts with KB* i want to make RCA Custom field(text field) Required.
Tried below script but not working. Script-1
import com.onresolve.jira.groovy.user.FieldBehaviours
import groovy.transform.BaseScript
@BaseScript FieldBehaviours behaviours
def Source= getFieldById('Source ID')
def RCAfield= getFieldByName('RCA')
RCAfield.required = false
if(Source.toString().contains('KB') ) {
    RCAfield.required = true
Script-2
def value=(String)getFieldByName('Source ID').value
if(value== 'KB-2209920')
getFieldByName('RCA').setRequired(true)
else
  getFieldByName('RCA').setRequired(false)
Andrea Pannitti
May 9, 2022
Hi @jaya chandra reddy nellore
you could try changing the first script as follow:
def Source = getFieldByName('Source ID').formValue
def RCAfield = getFieldByName('RCA')
RCAfield.setRequired(true)
} else {
RCAfield.setRequired(false)
jayachandrajira May 9, 2022
@Andrea Pannitti It's not working.
Fabio Racobaldo _Catworkx_
Hi @jaya chandra reddy nellore ,
welcome to the Atlassian community!
Here a correct behaviour code to associate to your field Source ID.
def sourcefield= getFieldByName('Source ID')
String sourceValue = sourcefield.getValue()
if(sourceValue.startsWith("KB")){
RCAfield.setRequired(true);
} else {
RCAfield.setRequired(false);
Please let me know if it works,
Fabio
@Fabio Racobaldo _Catworkx_  This is not working.
def RCAfield= getFieldByName('RCA Notes')
if(sourceValue.startsWith("IN")){
} else {
Do i need to add custom field RCA notes in behavior?
you need to add that code in a behaviour mapped to your project/issue type and for field "Source ID". It should work
@Fabio Racobaldo _Catworkx_  Please check below screen shorts, i am also following same but no use.
behavior script: Screen shorts 1 & 2
Checking behavior applied or not: Screen shorts 3 & 4Screenshot 1.png Screenshot 2.png Screenshot 3.png Screenshot 4.png
@jaya chandra reddy nellore , is Source ID in the same screen of RCA Notes? It seems no.
@Fabio Racobaldo _Catworkx_ Bothe are in the same screen, but both are in different tabs only.
please could you share me a screenshot of transition screen with both values?
May 9, 2022 edited
Hi @jaya chandra reddy nellore,
If you are using this for a Server-Side Behaviour, the correct approach to ensure that the Behaviour will be triggered is to use the fieldChanged to initialise the field the Behaviour is configured for, as shown below:-
def Source= getFieldById(fieldChanged)
def sourceValue = Source.toString()
if(sourceValue.contains('KB') || sourceValue.startsWith('KB') ) {
Please visit this ScriptRunner Training Video for more information.
I hope this helps to answer your question. :)
Thank you and Kind regards,
Ram
Dirk Ronsmans
Without going in to details already, I notice you use different methods for setting required.
and
Whats the idea here?
Also to get the value you need to use  formField.getValue() and not just .value
maybe a good idea to look thru the api quick reference first?
