We have a set of subtasks that need to be completed in a certain order. The subtasks are often assigned to different people. I would like to show a warning if someone starts subtask 3 before subtask 2 is completed.
We do have Scriptrunner. Is there a way to accomplish this?
Hello Laurie,
I have an idea you may like, but I have only tested it out on Power Scripts. First I will post the equivalent script in Groovy based on this Adaptavist documentation on validators and this one on subtasks.
The idea here is to loop through all the subtasks and break the loop once the current subtask is found. If the loop completes, throw an validator error.
def parent = issue.getParentObject().getIssueTypeObject().getName()
def subTasks = parent.getSubTaskObjects()
subTasks.each {
if (it.getKey() == issue.getKey()) {
break;
if (it.getStatusObject().getName() != "Done") {
throw new InvalidInputException("subtasks","Not all previous subtasks completed")
I did try this out on Power Scripts. Here is the script I used. Please see this documentation on subtasks routine and this one on validators.
string [] subtasks = subtasks(parent);
for (string subtask in subtasks) {
if (subtask == key) {
break;
if (subtask.status != "Done") {
return false, "status", "Previous subtasks have not been completed";
Full disclosure, I am a Product Engineer for Power Scripts and work for Anova Apps, an Appfire company.
Sure thing, Laurie! Please let me know how it goes!
Hyrum
Well, I'm not a developer, so I got a little stuck. I'll still digging, but would love some help if anyone can offer it.
Here's the code I'm using.
import com.opensymphony.workflow.InvalidInputException
def parent = issue.parentObject
subTasks.each {
break;
if (it.getStatusObject().getName() != "Testing") {
I'm getting the following error:
The script could not be compiled:
org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: Script32.groovy: 14: the break statement is only allowed inside loops or switches @ line 14, column 9. break; ^ 1 error
It seems that it isn't seeing the loop. Suggestions?
@Hyrum Steffensen {Appfire} any thoughts here? I realize you don't do Scriptrunner.
Has anyone with Scriptrunner done something similar to this? I'd love some input here. :)
Hello Laurie!
Thanks for reaching out! How about something like the following. In the code below, I have two subtasks, "EX-2" and "EX-3". Here are the steps the code takes:
import com.atlassian.jira.issue.IssueManager
def issueManager = ComponentAccessor.getIssueManager()
def issue = issueManager.getIssueObject("EX-3")
for (int i = 0; i < subTasks.size(); i++) {
def subtaskNumber = subTasks[i].getKey().findAll( /\d+/ )*.toInteger()[0]
def originalIssueNumber = issue.getKey().findAll( /\d+/ )*.toInteger()[0]
if (subtaskNumber < originalIssueNumber && subTasks[i].getStatus().getName() != "Done") {
return subTasks[i];
// throw new InvalidInputException("subtasks","Not all previous subtasks have been completed")
As previously stated, the "issue" variable should be provided by the validator context. As such, your code would look like this:
I hope that helps!
Hyrum
Thanks so much @Hyrum Steffensen {Appfire} for taking the time! Let me try this out and let you know how it goes.
Indeed! I would love to hear how it turns out!
Hyrum
@Hyrum Steffensen {Appfire} HUGE thanks again! I just realized I didn't respond to you to let you know this worked! Here's what I used:
log.setLevel(org.apache.log4j.Level.DEBUG)
log.debug "parent issue is $parent"
log.debug "subtaskNumber is $subtaskNumber"
def startedIssueNumber = issue.getKey().findAll( /\d+/ )*.toInteger()[0]
log.debug "started Issue number is $startedIssueNumber"
def evaluation = subtaskNumber < startedIssueNumber
log.debug "subtaskNumber is less than started issue number $evaluation"
def subtaskStatus = subTasks[i].getStatus().getName()
log.debug "status of subtaskNumber is $subtaskStatus"
if (subtaskNumber < startedIssueNumber && subTasks[i].getStatus().getName() != "Pass") {
log.debug "should throw error"
throw new InvalidInputException("Not all previous subtasks have been completed")
Worked like a charm!
Thanks again!
Laurie
Fantastic! Glad it worked, Laurie!
Please remember to mark this as the answer so that other Community users can find it.
Hyrum
