We couldn't create the subtask. Check your connection, then give it another try
Dan.anas August 1, 2019
Hi, Everyone.
I have a user who is receiving "We couldn't create the subtask. Check your connection, then give it another try", when attempting to add a subtask to a software project board. Any ideas on how to tackle this? User is able to traverse Jira in every other regard.
Thank you!
Dan A. - VARIDESK
2 accepted
7 votes
invinci
Hello everyone,
I ran into the same issue today and upon investigating further I realized the root cause is due to the new issue view. When you try to create a Sub-task against a jira issue with no existing linked issues and if your Sub-task create screen has mandatory customfields, then you will see the below error.
Workaround:
  1. Click on Actions from New Issue View.
  2. Select See the old view.
  3. Again click on Actions.
  4. Select Create a sub-task.
  5. The form pops up and users can successfully create Sub-tasks within the current issue.
This worked for me and I hope it does for you as well.
Vito_Abeln
January 22, 2020
Worked like a charm. Thank you.
Andy Matthews
May 27, 2020
Where is the "New Issue View"?
Like # people like this
Prakhar Sharma
April 7, 2021
Now the old view has been depreciated, how to do that ?
jisun lee June 27, 2021
Thank you!!!! you are so smart!!!
Sarah Oros
You may be able to add ?oldIssueView=true to the end of a issue URL if you cannot turn off the old issue view manually in settings. This solution worked for me.
gowtham.kumar August 2, 2021
Hi any  one send screen shot  for me not working
HI i got same problem , Iam unable to create a sub-task, please provide solution and clear view and send me screen shot
Greg Williams
Just wanted to thank @Sarah Oros for that "old issue view" trick, as it allowed me to go into the issue create screen and discover that the project's tickets were set to default to the Project Lead, and the Project Lead left the company and had their account disabled. Once I switched the default assignee to "Unknown" everything worked as expected.
Ismail Sanni
What I did was to clone an existing subtask I had...
Petter Gonçalves
August 2, 2019
Hello @Dan.anas
I understand that a specific user is facing an error when trying to create a sub-task from a specific issue in a board. Is it correct?
Please, provide us the following information so we can better troubleshoot the problem:
- Are there any other users facing the same problem?
- Is the problem happening when the user tries to create the sub-task directly in the issue instead of using the board like in the screenshot below?
- Is the problem happening only for a specific issue in the board or is it happening for any issue?
- Can you ask the user try to reproduce the problem in a different browser? Additionally, ask him to provide any errors returned in the Javascript console of the browser.
- Can you confirm if the sub-task issue has any required fields? The following bug causes an error if you try to create a sub-task with required field:
Cannot create subtasks if there is a required field on the new JIRA issue view.
Let me know if this information helps.
Rajesh Babu Bodapati
October 31, 2019
Tried in other browsers and different project boards  as well .. but no luck .. Out side the org network we could bale to create the subtask
Petter Gonçalves
October 31, 2019
Hello Rajesh,
Thank you for the information.
Since you are being able to avoid the issue outside your network, I recommend you to check with your infra team if the Cloud IP Addresses and Domains are properly whitelisted in your firewall and proxy:
Atlassian Cloud IP ranges and domains
Once you whitelist it, please let us know if the problem keeps happening.
Nguyen_Ngoc_Tu
January 8, 2020
I have the same problem. I cannot create subtask. Can you give me a solution?
Petter Gonçalves
January 13, 2020
Hello @Nguyen_Ngoc_Tu
Have you tried the options suggested above? Could you please share your results for each option you tried?
Bryan Bellamy
January 16, 2020
I am currently having the same issues after trying all suggested remedies above.
Petter Gonçalves
January 17, 2020
Hello @Bryan Bellamy
Investigating a little further, I found another possible reason for the error you are facing:
If a project has a default assignee but the default assignee does not have the assignable user permission, users will be prompted with the generic error you are seeing when creating a subtask through the new issue view:
Generic error message in the new view when creating a subtask
That being said, can you check if the default assignee under project settings > Details have the "assignable user permission"?
Jaime Bencia
March 23, 2020
Well done! This absolutely fixed my problem. Thank you. :)
Özer Uşak
September 28, 2020
I had the same issue and above solution worked well. Thank you
Bidul BabyDas
January 27, 2021
It worked! Thank You.
Tim
Thanks, faced the same issue. Changing the default assignee to "unassigned" did the trick.
A simple but correct error message could have saved a lot of time instead of "check connections and give it another try".
Piotr CHMIELEWSKI August 25, 2021
Exactly. For me the error message should have been "impossible to create a sub-task because the default assignee is an INACTIVE USER" (or something like that). I simply changed the default assignee and now it works.
Chris Weaver
September 3, 2021
This worked for me. When creating a non-subtask type you actually get a helpful error that tells you the default assignee does not have assignable permissions. Would be handy if that same error was triggered for sub-tasks.
3 votes
sdove
March 20, 2020
I was running into this issue myself, and found the problem in my case was that someone had removed the Summary field from the Subtask issue type. Adding that back on allowed us to create subtasks from the new ticket view again.
I found this out when I tried the use old ticket view mentioned above. I was able to get the pop up window to come up and noticed there was no place for the summary and went from there.
Hope this helps someone else.
Rik Ebbesen
April 18, 2021
This does help and thanks for sharing.  This is exactly what was my issue. back in business!
Like yazminqc likes this
BeeFC
The summary field was the cause indeed!
Drew Henderson December 2, 2021
THANK YOU
yazminqc
March 3, 2022
Thanks! That solved it @sdove !!!
Tereza Klobouckova
March 17, 2022
Thank you!!! It solved my issue.
Robson Nascimento
February 10, 2021
Someone has to look at this, for Christ sake
Drew Henderson November 23, 2021
@[deleted] please fix this? Absolutely atrocious error handling
Alex Harrison June 4, 2021
I am having the same issue for adding any type of task to an Epic.
1. I have checked the Project Details for Automatic Assignment and this is Unassigned.
2. It is not related to "Summary" of subtask being removed - but not 100% sure how to check this.
This needs to be fixed in the new version as we cannot keep going back to the old version.
Vimalraj Vemala
June 3, 2021
I too faced the same issue, it is resolved now. Thank you all.
One of the custom fields I created was made "Required", I changed it back to "Optional". Iam able to create subtasks now.
