Is there any free plugin available which provides that view or reports.
Basically currently the management is unaware about what's happening across all the projects, which projects are delivering things and where there is a delay.
What are the active resources and what things are happening across projects. Like how many bugs in totality we have across organization and projects.
Basically a organization level view.
Please suggest any marketplace free plugins which can help us on this case.
Hi @Vishal Gogari 👋
Add-on has a 30-day free trial version and free up to 10 users.
I suggest you to try Time in Status for Jira - one of the best monitoring and reporting tool in Jira. Our add-on has a lot of possibilities for Jira reporting. We have 7 types of status time reports such as Time in Status, Assignee Time, Average Time. All the reports you can display as Pie, Bar or Area Charts.
Also you can get cycle and lead time to uncover bottlenecks and delays
And last, but not least - we have Sprint Performance Report Sprint Performance Report where we have all the metrics for easy reporting.
Hope it helps 😌
Have you looked at creating a Dashboard? I have done this many times for management and it worked well.
Hi Jack,
I am aware of a dashboard but what i suppose it would be give me a view within the projects but not something for overall projects.
Not sure if I my understanding is correct. Please confirm.
Management wants to see overall high level view of JIRA and micro thing.
You can create a dashboard to be pretty much anything, bounded only by the JQL filter that you can create. So you can create a dashboard using various gadgets, and associate to the filters that you want. This obviously means that you can have a dashboard that spans all of your projects. Please note that if you have a lot of projects, then the dashboard will become quite busy. if you could provide more specifics about what metrics management, then I might be able to offer a more detailed subjective solution.
Sure thing Jack. Let me discuss with management team on what data they are planning to view. I shall get back to you soon.
Hey Jack,
I just tried to create one chart but there seems to be repetition of certain status's. Is it because project are not using shared settings? OR there might be a different reason to this?
It is because you are using team managed Projects. In those projects everything is unique to that project. So the status values in one project are not the same as those in another project, even if they are named the same. The only solution that I believe works for TMP in dashboards is to not combine those projects in a single gadget.
Got it Jack. Is there anyway I can convert these team managed projects to company managed ones.
OR the only solution is to create a project and move the issues to that.
Hi @Vishal Gogari,
A free plugin might not be available. But if you decide to look for a payed plugin, please consider our Great Gadgets plugin. It offers many gadgets that allows you to build powerful dashboard in Jira for tracking projects at the individual level, but also at the global (cross-release) level.
Just have a look over this article from our blog:
This is an example of overall release (cross-team) dashboard.
I hope this helps.
Danut.
1. You can try Reports - Charts and Graphs for Jira Dashboard app developed by our team to create various reports, charts and graphs for your Jira projects.
Below you can see an article about creating custom reports, charts and graphs in Jira with our app.
How to Create Custom and Flexible Reports, Charts and Graphs in Jira
Here is our live demo dashboard where you can see and modify sample reports and play with them.
For more detail, you can have a look at Reports - Charts and Graphs for Jira How to Videos.
If you are looking for a completely free solution, you can try the limited version Reports - Charts and Graphs for Jira Dashboard Free.
2. You can try Status Time Reports app developed by our team. It mainly provides reports and gadgets based on how much time passed in each status.
If you are interested in cycle time & lead time, you can have a look at the article below.
Cycle Time and Lead Time in Jira: Productivity Measurement with Two Critical Parameters
Here is the online demo link, you can see it in action and try without installing the app.
For further details, you can have a look at Status Time Reports How to Videos.
If you are looking for a completely free solution, you can try the limited version Status Time Reports Free.
Hope it helps.
if I may provide another Marketplace recommendation, I think you'd like the app that my team and I are working on, JXL for Jira. It's free to trial for 30 days, and will be free forever for up to 10 users.
JXL is a full-fledged spreadsheet/table view for your issues that allows viewing, inline-editing, sorting, and filtering by all your issue fields, much like you’d do in e.g. Excel or Google Sheets. It also comes with a number of advanced features, including support for (configurable) issue hierarchies, issue grouping by any issue field(s), sum-ups, or conditional formatting.
With these, you can build an organisation-level report like e.g. this in just a couple of clicks:
This is really just one example: You can group your issues by any (combination of) issue fields, in any hierarchy, etc. etc.; it all just depends on what information you'd want to get out of it.
Best,
Hannes
Hello @Vishal Gogari ,
I understand that you are not looking for a paid solution right now. However, if you ever need it I can recommend Timepiece - Time in Status for Jira which is built by my team at OBSS. It is available for both Jira Cloud, and Data Center.
Our app has a free 30 day trial and is free for up to 10 users. So please feel free to give it a try and present it to your management team.
Time in Status mainly allows you to see how much time each issue spent on each status or each assignee.
You can combine the time for multiple statuses to get metrics like Issue Age, Cycle Time, Lead Time, Resolution Time etc.
For all numeric report types, you can calculate averages and sums of those durations grouped by the issue fields you select. For example total in-progress time per customer or average resolution time per sprint, week, month, issuetype, request type, etc. The ability to group by parts of dates (year, month, week, day, hour) or sprints is particularly useful here since it allows you to compare different time periods or see the trend.
The app calculates its reports using already existing Jira issue histories so when you install the app, you don't need to add anything to your issue workflows and you can get reports on your past issues as well.
Time in Satus reports can be accessed through its own reporting page, dashboard gadgets, and issue view screen tabs. All these options can provide both calculated data tables and charts. And the app has a REST API so you can get the reports from Jira UI or via REST. Also you can export the reports in to various formats easily.
Visit Timepiece - Time in Status for Jira to explore how our JIRA add-on can revolutionize your metrics measurement process. Enjoy a 30-day free trial to experience the full range of features.
If you wish, you can also schedule a live demo. We will provide a comprehensive overview of the application and address any inquiries you may have.
Hope it helps,
Gizem
