We now have more than 1000 issues in our JIRA instance, however, the export to excel only exports the first 1000 issues.
I have searched the answers section of the help site and there is a suggestion that setting the &tempmax setting in the Excel URL to >1000 will work. I tried this and just get a 403 error.
Our entire reporting suite is based on this export. How do i reset the limit to more than 1000 ?
We can perform this for you, mate. But this will need some modifications to the system file in your instance.
Kindly raise a support ticket at https://support.atlassian.com and we will perform this for you. :)
