Web Resource : Could not find a file in configured directories
Marine Tm
I am trying to install web resource using script runner in my jira software test environement instance. However I am getting an error saying 'You need to configure at least one alternate resource directory before using a web-resource, see the documentation' & 'Could not find <tt>kb.css</tt> in configured resource directories:'.
I created one file 'kb.css' and put it under 'C:\Program Files\Atlassian\Application Data\JIRA\' location.
-> kb.css contains :
.cv-kb-portal-view .cv-kb-view-iframe-container .kb-view-iframe{
width: 100% !important;
.cv-kb-portal-view .aui-page-panel-inner.cv-kb-portal-view-inner{
width: 80% !important;
I have put this line 'JVM_REQUIRED_ARGS='-Dplugin.resource.directories=C:\Program Files\Atlassian\Application Data\JIRA\kb.css' in setenv.sh file as suggested in web resource documentation. I restarted jira instance several times but this seems taking no effect. I am still getting the same error as mentioned above.
I have entered below details in web resource :
Note : KB Window
Context : customerportal
Key : kb
Resources : kb.css
So how can I configure resource directory so my script file can be found?
Nic Brough -Adaptavist-
August 13, 2021
I suspect you might need to escape the space character in the path you've given to the plugin-resource-directory parameter
Marine Tm
@Nic Brough -Adaptavist-  Hello,
there is no space character
August 13, 2021 edited
Er, there very much is.  Please re-read the path you gave us, there is a space in "Program Files"
Marine Tm
Hello @Nic Brough -Adaptavist-  because there is a space in my desk as you see in this picture below
August 16, 2021
Right, so you see that there is a space in the path and what you said earlier is wrong. Try escaping it in the parameter.
Marine Tm
@Nic Brough -Adaptavist-  i will change the directory and see if it works ...
thank you
Marine Tm
the error persist
August 16, 2021
How have you escaped the space in the parameter?
Marine Tm
i finally found the mistake ....
my file kb.css is located on
'C:\Program Files\Atlassian\Application Data\JIRA'
then i just remove the \kb.css in the url :
Learn more
