Webhook String to custom date field
Neville April 19, 2024
{{webhookData.fields.Issue_date}}
In webhook data , it's return 2024/04/17.
I tried
1. {{webhookData.fields.Issue_date.jiraDate}}
2. {{webhookData.fields.Issue_date.jiraDateTime}}
3. {{webhookData.fields.Issue_date.jqlDate}}
4. {{webhookData.fields.Issue_date.jqlDateTime}}
5. {{webhookData.fields.Issue_dateformat("yyyy-MM-dd")}}
6. {{webhookData.fields.Issue_date.toDate()}}
All of them are return null.
I would like to put this value to update a custom date field
Kai Becker
Hi @Neville
thank you for your question. What type of field is Issue_date?
Is this also a custom field? Or is this webhook data from an external source?
If it is a valid date value, you should be able to populate another field with this issue regardless the date format.
Hi @Kai Becker
The Webhook data is from external source.
Kai Becker
Hi @Neville
I guess the problem then is the format. Jira needs to recognize the value as a date.
please try the following:
or
{{webhookData.fields.Issue_date.toDate("yyyy/MM/dd")}}
Like # people like this
