Hello everybody,
I'm trying to use webhooks in my Atlassian connect addon. I add this snippet in my descriptor.json and it works
.... "webhooks": [ { "name": "test", "events": "jira:issue_updated", "filter": "project = test", "url": "/mainIssue", "excludeBody": false } ]
I need to add "jira:issue_created" also without duplicating the code I tried this but it doesn't work
"webhooks": [ { "name": "test", "events": [ "jira:issue_updated", "jira:issue_created" ], "filter": "project = test", "url": "/mainIssue", "excludeBody": false } ]
Would you have any proposition how I can specify more events ?
Best regards
You need to specify a new webhook object for each event:
.... "webhooks": [ { "name": "test updated", "events": "jira:issue_updated", "filter": "project = test", "url": "/mainIssue", "excludeBody": false }, { "name": "test created", "events": "jira:issue_created", "filter": "project = test", "url": "/mainIssue", "excludeBody": false } ]
Jon
Thanks @Jon Bevan [Adaptavist] that's what I want to avoid it. That's mean that I will duplicate the code. But if there is not any way I will do like that
