Sign up Log in
What are the downsides of using issue security in jira project
simarpreet singh
Are there any downsides of using issue security like performance degradation,etc.
Or it's fine to use that in our project.
Nic Brough -Adaptavist-
July 22, 2020
Yes, there are two downsides
Hiding issues from people is extra effort.  You are making your server work harder, which means "not as fast".  But if you keep your issue security schemes simple, you will never notice the load it imposes.  @Sachin said <10 levels and I agree - when you do have a good need for a security scheme, keep it as simple as you can.  You really won't notice it if you keep the levels simple.
Hiding issues from people means you are not working together.  Don't do that.
Sachin
July 22, 2020
Hello @simarpreet singh , no there won't be much performance effect on your Jira for setting up issue security on your project. But, there is a possibility that too many Issue Security Levels can impact JIRA performance, so keep the security levels < 10.
