What are the pre-requisites to creating a next-gen project?
Shawn_L_ April 15, 2019
What are the pre-requisites to creating a next-gen project? I don't see that option in the menu items.  Thanks.
Chris Nicosia
April 15, 2019
@Shawn_L_ - next-gen projects are only available for Jira Cloud.  Are you using Cloud? Or are you using Jira Server/Data Center?
Jack Brickey
and if you are on Cloud and you do not see the image below then check w/ you admin as they may have it disabled.
Learn more
