What does "irrelevant" mean in a JIRA pie chart
Jason Friedman
April 21, 2016
There is no link available to see which issues are included in that slice.
3 votes
Benn Ingersoll
Came across this question while looking for the answer to it myself.  Since then, I've figured it out (at least for my situation)...
It looks like Irrelevant shows up when you have an issue type in your filter that doesn't have the field you are grouping by.  So, in your case, you must have 17 issues of an issue type where the "Raised In Versions (all)" custom field isn't available.
There really isn't a great way to get that list of "Irrelevant issues" in JIRA (since you can't use the "Raised In Versions (all)" in your search), although you could try adding an Issue Type filter to your query and exclude any issue types where you know that field is available.
Hope this helps!
Philip Schlesinger June 3, 2019
Came across this myself:
The "Irrelevant" state was replaced by "Backlog" a few minutes later when I next looked at that pie chart.  Me thinks the cause was an issue was in the process of a change of Status at the time of the pie chart being rendered...so it was in an indeterminate Status.  Maybe they should call it instead "Schrödinger"? :)
Like • Bill Sheboy likes this
Daniel Carroza
July 15, 2020
Nic Brough -Adaptavist-
April 21, 2016
It looks like you have a version called "irrelevant", but I don't know where the link has gone.
