What is the best way to do an auto sprint placement?
dorin gez June 3, 2021
We work with only one sprint so there is no point in choosing a sprint any create operation.
Trudy Claspill
Hello @dorin gez
Can you provide more information about your scenario and what you are trying to accomplish?
Do I understand correctly that you want your issues to automatically be assigned to a sprint when you create them? Typically issues go into the Backlog when they are created, and you select which of the issues you want to work on in your sprint during Sprint planning. Are you not accumulating issues in a Backlog and then selecting a subset of those issues for your upcoming sprint during Sprint Planning?
