Hi.
We are a digital marketing agency and we have tasks that we do periodically and others that we do on demand.
Every task is done for a customer. So, my question is what is the best way to implement this relation?
We need to be able to:
- View reports by customers.
- Filter Issues by customer
- Create issues thoug RestAPI selecting customer
- Create customer thoug RestAPI
So far I have 2 options:
1) Custom field "Client" (combo select). But could not find how to use it in filters and the RestAPI option to add values to custom fields is not available
2) Atlas CRM: it cost $2,5 per user/month and dont have RestAPI available.
Any comment is wellcome,
Many thanks!
I would first consider using Components for your clients/customers. If you are already using Components for something else then add a new customer field. Last you could consider different projects per client but that isn’t ideal IMO.
Thanks for the reply. I will investigate what components are and how should we implement them for this purpose.
Maarten from Atlas CRM here. We don't have an API available at this moment, but this is something we plan on implementing.
Our efforts are currently going into a Server / Data Center version of Atlas CRM. An API for this version is high on our backlog, after which we want to make the API available on Cloud as well.
If you haven't done so already, feel free to contact us so we can let you know once the API is available.
Do you know when the API will be implemented in Cloud version? And on Server?
More detailed info would be better. Its a big step for the organization.
