The about page on our onDemand instance suggests that Tempo Planner has been enabled. But I've tried to reference the API using the following URL with no success:
https:
//[company].atlassian.net/jira/rest/planner/1/allocation/assignee?assigneeKey=admin&assigneeType=user&startDate=2016-11-01&endDate=2014-12-31
Can you please send me a correct URL?
Hi Richard
Don't know if you've solved this, but for others looking for the same, I've used the following with success:
Hope this helps
Hi Susanne,
I tried the URL as indicated above, but still no joy,
I have a license for Timesheets ans Planner,
I simply get a 404 error in return
my url looks as follows
image2016-12-1 9:53:14.png
Hi Richard,
can you try to use the URL
https:
//[company].atlassian.net/rest/planner/1/allocation?assigneeKeys=admin&assigneeType=user&startDate=2016-11-01&endDate=2016-12-31
This should return the plans that are made in Tempo Timesheets or Tempo Planner for a User with the username "admin" that are within the set timeframe.
Please note that this is only possible if you have a valid license for Tempo Timesheets or Tempo Planner.
Susanne
