What is the correct format for jira transition object while using in rest API ?
Rahim T_S
February 1, 2023 edited
I have be using https://www.npmjs.com/package/jira-client to create a JIRA utility and to update issue status via API
I initially listed all the transitions using
jira
  .listTransitions(<issueId (redacted)>)
  .then((result) => {
    console.log(result);
  .catch((err) => {
    console.error(err);
and got
expand: 'transitions',
transitions: [
{ id: '4', name: 'Start Progress', to: [Object], fields: {} },
{ id: '5', name: 'Resolve Issue', to: [Object], fields: [Object] },
{ id: '2', name: 'Close Issue', to: [Object], fields: [Object] }
So to transition the issue, I used the API available
jira
  .transitionIssue("redacted issue number",{id: '5', name: 'Resolve Issue', to: [Object], fields: [Object]})
  .then((result) => {
  .catch((err) => {
    console.error(err);
since this API requires two input fileds,
issueId: string, issueTransition: JiraApi.TransitionObject
but I'm getting an error saying
Can someone help me figure out what is the correct format of TransitionObject ?
Error: {"errorMessages":["Can not deserialize instance of java.util.LinkedHashMap out of START_ARRAY token\n at [Source: org.apache.catalina.connector.CoyoteInputStream@2115007d; line: 1, column: 45] (through reference chain: com.atlassian.jira.rest.v2.issue.IssueUpdateBean[\"fields\"])"]}
Rahim T_S
Found the solution
jira
  .transitionIssue("<issue number>", {
    transition: {
where 3 or any number corresponds to the available transitions for that issue
