What is the proper way to use "@mentions" in the comments of Activity Stream widget
Tom Napper April 23, 2015
When using the Activity Stream widget on my dashboard the "@mentions" in the comment sections do not link to a user profile like it does when using the "@mentions" in a comment in the open issue.
Action:
  1. In the Dashboard widget Activity Stream click on the "comment" link for a issue
  2. type @with the appropriate user name
  3. click "add"
Result: the comment is added as typed
Expected Result: the "@mention" gets re-formatted to a link to the user profile
Paulo Junior
April 24, 2015
What happens if your type:  [ ~user] ?
Tom Napper April 24, 2015
Yes! that works! Adding a bracket, then a tilda before the "user name" creates a link! Terrific!
Read the story
