What's the query for days in column?
Tim Kelly
January 30, 2019
I'm trying to figure out how to replicate the functionality that we see when we place our cursor over the dots on a card and the alt text shows us "x days in column". I'm guessing there is some sort of JQL query that's calculating this and not something as simple as a field that can be queried. Any ideas?
Jonas Bang Christensen January 31, 2024
Try to see my answer here, does that solve the problem:
JQL query to show "days in column" for issues (atlassian.com)
Alexey Matveev
January 30, 2019
You would need to write your own custom field for it.
Tim Kelly
January 30, 2019
I'm looking for the query that is used to calculate the days in column.
This way, I can use the same logic to build a report in a third party dashboard tool. I'm just not sure how they are coming up with that information in the first place, it's there somewhere though.
Like • erica.sikorski likes this
Alexey Matveev
January 30, 2019
You can read more info about the days in column field here:
https://confluence.atlassian.com/agile/jira-agile-releases/jira-agile-release-notes/jira-agile-6-6-release-notes/jira-agile-6-6-11-release-notes?_ga=2.65230574.1513002746.1547637396-1149622764.1547637396#JIRAAgile6.6.11ReleaseNotes-
If you need more info, you would need to look in the source code of Jira Software. But it is not available.
Like • 2 people like this
Alex James
May 13, 2019
I can confirm Alexey is correct.  Need to incorporate this field into out of the box cloud instance for reporting purposes.
K Akshay Hegde June 27, 2022 edited
@Tim Kelly   Did you find the solution for this?.. Even i am stuck with the same problem.
Like • Ahmed Diaa likes this
Sebastian Castillo
April 26, 2023
I'm also looking for a JQL way to pull the data, but I have only found plugins so far.
I believe it needs to be a way to do it.
Hi @Sebastian Castillo
Try to see my answer here, does that solve your problem:
