When an issue goes to a "Complete" status, how can I change all fields to read-only?
Brian May 1, 2015
We want to make a project issue read-only when the status changes to Complete.  How can this be done?
Nic Brough -Adaptavist-
May 1, 2015
The standard way to do this is to use the workflow properties - look for jira.issue.editable on https://confluence.atlassian.com/display/JIRA/Workflow+properties
Brian May 1, 2015
Is there a system default setting?
May 1, 2015
No, it's a workflow function.
Brian May 1, 2015
I was told this isn't available in the Atlassian Cloud version.
May 1, 2015
It isn't. I'm afraid it's also the wrong answer, as you can do it with Jira off-the-shelf, and the Behaviors addon is now part of the script runner.
Nuwan
Hi Winter
I think you might interest in use of plugin for this..try Behaviours Plugin ..
https://marketplace.atlassian.com/plugins/com.onresolve.jira.plugin.Behaviours.
