×jira server is in use.
If you check Agile board/kanban board/Active Sprint when the structure is enabled after the latest 8.5.1 update, the menu is not displayed normally.
As shown in the screenshot below, the sidebar is not displayed, and when the top menu is clicked, the lower menu does not appear.
Can you help with this?
Hi @내미랑다롱이랑,
From your description, it looks like this is happening after a Jira upgrade?
Moga
thanks @mogavenasan
i already solved this problem.
It was caused by the JIRA Suite Utilities add-on.
