When finding the issues using labels, Is it possible to use just some common characters?
Jiebyoung Park
February 12, 2019 edited
In the Jira system, When finding the issues using label, I would like to use just some common characters of label.
 For example, If there are so many labels such as "ABC_01, ABC_02, ABC_03..... and so on, I would like to find them just using "ABC" characters likewise ABC*.
Deleted user February 13, 2019
Hi @Jiebyoung Park
There is already an open suggestion JRASERVER-23038 to allow Search for labels using wildcards. Please vote on the issue to add yourself as a watcher to the request to get future updates.
Vijay Ramamurthy
Sreenivasaraju P
February 13, 2019
Hi @Jiebyoung Park,
I don't think , out of the box this is possible. As Labels field doesn't supprot ~ operator. It supports only =, !=, is not, is, not in, in operators.
You can try with labels in (ABC_01, ABC_02, ABC_03) option.
