Hi @Natalie Keane
To determine which Screen Scheme your project is using, follow these steps:
Navigate to Project Settings:
- Go to your project in Jira.
- In the sidebar, click on Project settings.
Locate the Issue Type Screen Scheme:
- Under the Issues section, click on Screens.
- Here, you will see the Issue Type Screen Scheme associated with your project.
Drill Down to the Screen Scheme:
- Click on the name of the Issue Type Screen Scheme to view the mapping of issue types to Screen Schemes.
- Each Screen Scheme defines the specific screens (e.g., Create, Edit, View screens) used for that issue type.
Identify the Screens Used:
- Once in the Screen Scheme, click on each screen to identify the fields displayed on those screens.
- You can also verify which custom fields are added to a specific screen.
If you’re a Jira product administrator and want a higher-level view,
- Click on ⚙️ → Issues from top navigation bar.
- Under Issue Type Screen Schemes all configured screen schemes and their associated projects will be listed.
You can match these to the issue type screen schemes assigned to your projects.
