Where is my field error
Aaron Clancy
November 26, 2014
When trying to add a custom field like due date for an issue - it comes back with an error saying:
The JIRA server was contacted but has returned an error response. We are unsure of the result of this operation.
Can anyone give some guidance on this?
Diego Zarpelon
November 27, 2014
Hello Aaron,
as Mizan said before, to help you on this we should take a look on your log files to review what's causing this. As this is a pretty generic error there's a lot of reasons that can be causing this. So please take a look at your $JIRA_Home/log/atlassian-jira.log file and see if you can find any exception on it and paste it here so we can help you on it.
laugh
Diego Zarpelon
Michela Baca March 8, 2018
I am also having this issue however, we are on the Cloud version so I don't have access to the logs.
Radu Dumitriu
November 26, 2014
Nobody cannot say for sure, unless you put here some logs, a better description of the problem, etc.
Aaron Clancy
November 26, 2014
No you can't - it is just a one liner - it is a pop up and you can only click close. Any ideas? Happens when I select any custom option when creating an issue.
Mizan
November 26, 2014
You can expand the response and see the exception which occurred. The exception will give us an idea what exactly caused the error.
