Where is the custom fields ID?
Aoife Browne August 26, 2019 edited
I found an error with my emails creating tickets and it says its due to a value in the customfield_10235. When I go into the custom fields it does not show their original code name like this one. How do I find this custom field ?Custome field.PNG
2 accepted
Sreenivasaraju P
August 26, 2019
You can find custom field id by configure option on custom field
or you try below url , you will get the custom field with the id = 10235
<your server url>/secure/admin/ConfigureCustomField!default.jspa?customFieldId=10235
Ken August 26, 2019 edited
Hi Aoife,
you can find the custom field ID in the URL when you try to View / Configure it in the Custom Field Configuration menu. More details here: https://confluence.atlassian.com/jirakb/how-to-find-id-for-custom-field-s-744522503.html
Hope this helps.
Regards
Thank you Kenadit, I found the custom field.
Aoife
David Clark July 29, 2024
The answer is simple its in the URL look for id=
