Where is version 1.19?
Marc
August 25, 2013
Hi, I'm trying to import an project from an on-demand Jira instance, into a local instance. The import is currently blocked because the source charting plugin is in version 1.19 while target is 1.16. Currently 1.16 seems to the latest generally available version, so my question is, when will I be able to export/import my project?
//Marc
RambanamP
August 25, 2013
yes you are correct, when i select ondemand on plugin home page it is showing message as follows
"Note that the OnDemand version of this add-on is separate from the download version. Version details and screenshots have changed to match your selection."
submit a support request @http://support.atlassian.com
Matze Heinz
November 17, 2013
Similar issue here. Tried to import jira (from a hosted jira - plugin version 1.20) getting the version error. Latest available Version for download is 1.19.1.
When gets the 1.20 version for the charting plugin available for download instances?
Marc
August 25, 2013
So let me elaborate.
The following links to a screenshot of our on-demand Jira instance plugin list as you see the charts plugin is somehow in version 1.19.
See the error we get when importing here
RambanamP
August 25, 2013
recheck about the version 1.19 or it is 1.9(JIRA 5.1 compatibility) because the latest version it self is 1.16(JIRA 6.0 - 6.0.7)
check the version matrix here
https://marketplace.atlassian.com/plugins/com.atlassian.jira.ext.charting/versions
Register here ⬇️
