While importing using Json , Priority value is not available
Karthick Jaganathan August 2, 2023
Caused by: com.atlassian.jira.plugins.importer.imports.csv.ImportException: Priority [ Lowest ] is not in the project [ RA ] Priority Schema.  Also Priority Schema couldn't be changed, because it's shared by more than one project.
	at com.atlassian.jira.plugins.importer.imports.importer.impl.PriorityUtils.preFilterPriority(PriorityUtils.java:60)
	at com.atlassian.jira.plugins.importer.imports.importer.impl.ExternalUtils.convertExternalIssueToIssue(ExternalUtils.java:543)
	at com.atlassian.jira.plugins.importer.imports.importer.impl.DefaultJiraDataImporter.createIssue(DefaultJiraDataImporter.java:887)
I am trying to import Issues via JSON, though the priority values are available it is throwing above error.
Kian Stack Mumo Systems
@Karthick Jaganathan
It's saying that the value is not available in the priority scheme set for that project. Can you confirm if that is the case?
Kian
No Kian its available.
I just added all the values as per source.
What is the exact string of text in your JSON? Can you share the line you have for that priority along with a screenshot of your priority scheme tied to the project RA?
Kian
JSON :
items" : [ {
          "fieldType" : "jira",
          "field" : "priority",
          "oldValue" : "3",
          "oldDisplayValue" : "Medium",
          "newValue" : "5",
          "newDisplayValue" : "Lowest"
"key" : "RA-233",
      "summary"
      "reporter"
      "assignee" : ,
      "description" : "Om in de toekomst meer te kunnen doen met het massaal analyseren van reviews, emails en andere tekstuele reacties van klanten is het wellicht handig om NLP of semantische analyses te leren die in bijvoorbeeld Python uitgevoerd kunnen worden. Deze analyses kunnen vervolgens gebruikt worden om aan te geven of de algehele stemming positief of negatief is.",
      "issueType" : "Story",
      "status" : "Backlog",
      "priority" : "Lowest",
      "created" : 1662022756742,
      "updated" : 1682332227022,
      "components" : [ "Datacleaning" ],
      "watchers"
      "history" : [ {
        "author"
        "created" : 1662022760285,
        "items" : [ {
          "fieldType" : "custom",
          "field" : "Rank",
          "newDisplayValue"
Everything looks fine in your data. It looks like someone else ran into this issue - https://community.atlassian.com/t5/Jira-questions/JIRA-CSV-Import-priorities/qaq-p/744932.
I would consider raising a ticket with Atlassian as this could be a deeper bug. I tried to find an existing bug in their system related to this, but I didn't have any luck.
