While moving from one transition to another transition we are getting error like "Unable to find fie
Naresh April 21, 2022
While moving from one transition to another transition we are getting error like "Unable to find field 'customfield_13800'". But there is no custom field on 13800 in the instance and databaseMicrosoftTeams-image (2).png
Tuncay Senturk _Snapbytes_
Hi @Naresh
It seems that customfield_13800 is used in one of the workflow validators of the transition.
Could you please check the transition and make sure there is nothing wrong there?
Let's build A Rovo Agent 🤖
Save your spot
