×HI Team,
I hope someone can help me here with this simple question.
I work with 2 projects in Jira which basically uses the same fields.
Field 1 has a different setting from Field 2 (image below). Although these fields were set up using Aa text . They are behaving differently.
* With field 1 I can search, organize by alphabetical order, extract in a report, etc.
* With Field 2 I cannot do any of that and I cannot understand why.
THE QUESTION IS;
How can I set up field 2 as field 1,
or
where is Field 1 hidden in the field's list - if I can find it, I could add it to the second project.
FIELD 1
FIELD 2
Hello @Paulo.Cerqueira
What happens when you try to "search, organize by alphabetical order, extract in a report, etc." for Field 2?
Tell us about the specific actions you are taking, what you expect the results to be, and what the actual results are.
Show us the actual results/data so we can see how that compares to your expectations.
Hi Trudy,
Thanks for your swift reply and sorry for my late response. :-)
I understood now the differences between them;
Field 1; Was created in a team project which gives the creator this flexibility to order the data in alphabetic order for example.
Field 2; Was create globally which gives the creator another type of flexibility which goes beyond the scope of this question.
For the moment I'm satisfied with this understanding and I got what I wanted.
Thanks Again.
