Why I can't create an issue collector?
Radu Palicica July 6, 2015
I've just created a new project using the default workflow scheme. Assigned an administrator, a developer and a user.
If I try to create an issue collector by hitting Submit I'm getting neither an error message nore being redirected to the issue Collectors list view page. The page does refresh when hitting the Submit button.
Am i doing anything wrong?
Radu
4 votes
Paula Silveira
July 6, 2015
Hi Radu,
Please ensure it's possible to create issues without assignee. You can check it by doing the following:
  1. Access JIRA as administrator
  2. Click on the cogwheel icon (on the top menu)
  3. Click on System
  4. Click on Edit Settings
  5. Search for Allow unassigned issues, select ON next to it
  6. Click on Update, at the bottom of the page
Thanks and regards,
Paula Silveira
Molly Jones
January 27, 2016
This worked for me as well. Thank you, Paula!
Mark Allen
October 25, 2018
Hi @Paula Silveira
I have the same issue, but not the same cause: Allow unassigned issues is already 'ON'.
Are there any other known causes?
The form refreshes and maintains the data, but there is no alert. I have also tried in multiple browsers.
Mark
Like • 3 people like this
Deleted user January 28, 2019
Hello @Mark Allen
Did you find any root cause? I am facing the same issue right now.
Cheers!
Anna
Mark Allen
January 29, 2019
Hi @[deleted]
Yes. I changed the type of issue created from Story to Bug and it worked.
I hope this helps.
Mark
Like • 2 people like this
Deleted user January 29, 2019
Hi @Mark Allen
Before I saw your answer, I noticed that in my default field configuration (that I used for issue collector) time tracking is mandatory field.
I used other field configuration for this project, where ONLY "Reporter" field is required and it worked.
Maybe Bug and Story issue type had different field configuration in your case.
Thank you so much for your help.
Anna
Lowrider614
May 6, 2020
If someone comes by and does not find his/her solution in the above entries.
Another reason for the above failure is setting fields as required that the issue collector cannot display. In my case, this was a user picker field type. Refer to the issue collector manual for futher information.
https://confluence.atlassian.com/adminjiracloud/using-the-issue-collector-776636529.html
Thanks a lot, this fixed my problem. Thanks for the speedy reply. Much appreciated.
Radu
Register now
