Why Jira logout automatically sometimes?
Raw Main
After login into Jira, sometimes when redirect to an another page, it will logout automatically.
From log I found this one. Is it the reason?
2020-09-23 17:33:18,539+0900 localhost-startStop-1 DEBUG      [c.a.activeobjects.osgi.ActiveObjectsServiceFactory] getService bundle [com.pyxis.greenhopper.jira]2020-09-23 17:33:18,751+0900 localq-reader-14 WARN      [c.a.j.c.distribution.localq.LocalQCacheOpReader] Runtime exception: UnrecoverableFailure occurred when processing: LocalQCacheOp{cacheName='com.atlassian.webhooks.plugin.store.WebHookListenerCachingStore.listeners', action=REMOVE, key=com.atlassian.cache.impl.ReferenceKey@0, value=null, creationTimeInMillis=1600849998731} from cache replication queue: [queueId=queue_node3_4_1315e07dc5ecfdcec39f54ec16f564b7, queuePath=/home/jira/jirasoftware-home/localq/queue_node3_4_1315e07dc5ecfdcec39f54ec16f564b7], failuresCount: 1/2, error: java.rmi.NotBoundException: com.atlassian.webhooks.plugin.store.WebHookListenerCachingStore.listeners2020-09-23 17:33:18,761+0900 localhost-startStop-1 INFO      [c.a.jira.scheduler.JiraSchedulerLauncher] Starting the JIRA Scheduler....2020-09-23 17:33:18,763+0900 localq-reader-14 WARN      [c.a.j.c.distribution.localq.LocalQCacheOpReader] Abandoning sending because cache does not exist on destination node: LocalQCacheOp{cacheName='com.atlassian.webhooks.plugin.store.WebHookListenerCachingStore.listeners', action=REMOVE, key=com.atlassian.cache.impl.ReferenceKey@0, value=null, creationTimeInMillis=1600849998731} from cache replication queue: [queueId=queue_node3_4_1315e07dc5ecfdcec39f54ec16f564b7, queuePath=/home/jira/jirasoftware-home/localq/queue_node3_4_1315e07dc5ecfdcec39f54ec16f564b7], failuresCount: 2/2. Removing from queue. Error: com.atlassian.webhooks.plugin.store.WebHookListenerCachingStore.listenersjava.rmi.NotBoundException: com.atlassian.webhooks.plugin.store.WebHookListenerCachingStore.listeners at sun.rmi.registry.RegistryImpl.lookup(RegistryImpl.java:227) at sun.rmi.registry.RegistryImpl_Skel.dispatch(RegistryImpl_Skel.java:115) at sun.rmi.server.UnicastServerRef.oldDispatch(UnicastServerRef.java:468) at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:300) at sun.rmi.transport.Transport$1.run(Transport.java:200) at sun.rmi.transport.Transport$1.run(Transport.java:197) at java.security.AccessController.doPrivileged(Native Method) at sun.rmi.transport.Transport.serviceCall(Transport.java:196) at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:573) at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:834) at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.lambda$run$0(TCPTransport.java:688) at java.security.AccessController.doPrivileged(Native Method) at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:687) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748) at sun.rmi.transport.StreamRemoteCall.exceptionReceivedFromServer(StreamRemoteCall.java:283) at sun.rmi.transport.StreamRemoteCall.executeCall(StreamRemoteCall.java:260) at sun.rmi.server.UnicastRef.invoke(UnicastRef.java:375) at sun.rmi.registry.RegistryImpl_Stub.lookup(RegistryImpl_Stub.java:119) at com.atlassian.jira.cluster.distribution.localq.rmi.BasicRMICachePeerProvider.lookupRemoteCachePeer(BasicRMICachePeerProvider.java:64) at com.atlassian.jira.cluster.distribution.localq.rmi.BasicRMICachePeerProvider.create(BasicRMICachePeerProvider.java:39) at com.atlassian.jira.cluster.distribution.localq.rmi.CachingRMICachePeerManager.getCachePeerFor(CachingRMICachePeerManager.java:58) at com.atlassian.jira.cluster.distribution.localq.rmi.CachingRMICachePeerManager.withCachePeer(CachingRMICachePeerManager.java:91) at com.atlassian.jira.cluster.distribution.localq.rmi.LocalQCacheOpRMISender.send(LocalQCacheOpRMISender.java:63) at com.atlassian.jira.cluster.distribution.localq.LocalQCacheOpReader.run(LocalQCacheOpReader.java:84) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748)
Register today
